It is currently Mon 15. Jun 2026, 10:30
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
PostPosted: Tue 23. Nov 2010, 10:22
Here we are presenting further explanations together with some examples of the use of the formulas. You may use the search-functionality of the forum to find them, e.g. looking for if(), min() etc..
Please do also add your examples and explanations of the formula as some of them are just of use for very specific challenges that Consideo itself has no experience with.
 Post subject: abs() formula
PostPosted: Tue 23. Nov 2010, 10:25
abs() calculates the absolute value of something to -6 becomes 6, -3 becomes 3 etc...
absFormula.cons [7.31 KiB]
Downloaded 92853 times
 Post subject: acc() formula
PostPosted: Tue 23. Nov 2010, 10:27
acc() does the same a level factor does. It summarizes values of e.g. a connected factor over time
accFormula.cons [5.98 KiB]
Downloaded 75612 times
 Post subject: and() formula
PostPosted: Tue 23. Nov 2010, 10:30
and allows to extend conditions in an if() formula
andFormula.cons [10.55 KiB]
Downloaded 67318 times
 Post subject: average() formula
PostPosted: Tue 23. Nov 2010, 10:38
average() allows to calculate a recent trend of a series of values. In the example file it is the average of the last three values.
Please note that the average for the first two results includes one or two values of zero ... ...
For an overall average see midvalue()
averageFormula.cons [5.81 KiB]
Downloaded 71951 times
PostPosted: Mon 29. Nov 2010, 14:22
The averageE() and the averageW() formula both smooth a series of values... best shown by example
averageEuWFormula.cons [18.17 KiB]
Downloaded 73191 times
 Post subject: date() formula
PostPosted: Mon 29. Nov 2010, 14:36
The date() formula allows to make calculations depended from a date, like shown in the example....
dateFormula.cons [8.77 KiB]
Downloaded 66713 times
PostPosted: Mon 29. Nov 2010, 15:04
The smooth1() smooth3() delay1() and delay() functions are all for certain, nonlinear delays that result in a sort of smoothing on values. Their benefits are best described with the example and the pdf-papers attached ....
File comment: English Paper based on Vensim
DelaysSmoothing.pdf [207.24 KiB]
Downloaded 161849 times
File comment: Deutsche Erläuterung bezogen auf Vensim
Downloaded 132354 times
delayANDsmoothFormulas.cons [22.45 KiB]
Downloaded 66139 times
 Post subject: gauss() formula
PostPosted: Mon 29. Nov 2010, 15:34
The gauss() formula transforms a linear input-series to a gauss-shaped input-series. In practical terms that is probably needed for only a few, rather static calculations. For a real distribution of likelihoods you should refer to the description of the Monte-Carlo-simulation in our manual that comes with the MODELER.
gaussFormula.cons [6.02 KiB]
Downloaded 129467 times
 Post subject: modulo() formula
PostPosted: Mon 29. Nov 2010, 16:16
the modulo() formula returns the residue of a division .... like shown in the example
moduloFormula.cons [10.7 KiB]
Downloaded 133949 times
