It is currently Wed 29. Jul 2026, 23:00
PostPosted: Tue 1. Feb 2011, 09:00
Here's an example on how to structure a PROCESS MODELER model to run Monte Carlo scenarios on possible developments and how to use the range() formula to identify an optimal input of resources (performing hard operations research).
You can easily add any detail from your specific challenge. Use the MODELER-Forum to ask for further help...
File comment: Screenshot showing the Monte Carlo simulation
File comment: Screenshot showing how to select a scenario and see what combination of resources lead to it. Of course, you can zoom into the diagram to pick the optimal scenario ...
File comment: the model with the range() optimization
ComplexityLogistics10PMRange.cons [260.09 KiB]
Downloaded 7800 times
File comment: the Monte Carlo model
ComplexityLogistic10PMMC.cons [267.04 KiB]
Downloaded 8464 times
