It is currently Wed 26. Aug 2026, 20:51
PostPosted: Thu 28. Apr 2011, 19:25
Here's a small example on how to identify parameters of conditions that determine an outcome like you usually need for forecast models. It is somehow an alternative to multiple regression analysis. The model is comparable well documented and hence a template for free :D
It is using our mighty range() function and the cross impact diagram.
Make use of it
File comment: quantitative, version 7, less than 20 factors suitable also for demo version
MultipleRegressionAnalysis.cons [26.52 KiB]
Downloaded 9498 times
